Fresh Water Tank Leak
- Been thanked: 646 times
Re: Fresh Water Tank Leak
https://www.trioniccorp.com/marine-wate ... aste-tank/
- Has thanked: 598 times
- Been thanked: 1281 times
- Been thanked: 601 times
- ronmar
- Vessel Info: 1993 350 Aft Cabin
- Has thanked: 21 times
- ronmar
All the plastic tanks found have slightly different fitting configurations. They come with two 1/2" female fittings and two 1 1/2" fittings.
I'm confused on which 1 1/2" fitting to use since original was at bottom of tank.
- ronmar
"This is how the tank works. Both tanks would work the same way. You should be able to take the metal tank out and put the plastic tank in.
The water inlet is on the bottom left on the tank.(1-1/2”)
The water to the pump is on the bottom right.
The fitting on the top is the vent that goes out to the side of the hull. As you fill this tank it pushes the air out the top. If you over fill this it will run out the side of the boat."
- Has thanked: 469 times
- Been thanked: 1765 times
