Tranny Chatter 1000-1400 RPM
- Sadey
- Vessel Info: Former owner of a 2003 Carver 356 with 8.1 Mercs
Agradecida
Current owner 1989 60’ Hatteras MY with 8v92 Detroit’s
Benedetto - Location: Racine Wisconsin/Ft. Lauderdale
- Has thanked: 4 times
- Been thanked: 29 times
Dave & Trina
- Sadey
Agradecida
Re: Tranny Chatter 1000-1400 RPM
Dave & Trina
Good luck.
The chatter could be a number of things from the tranny to the engine. Tom is correct re the damper plate, could also be an engine runnability issue causing the tranny to react that way. Are you sure it's coming from the tranny? A broken off damper in a muffler can cause a chatter as well but because everything is in the same area, it may sound like it's coming from somewhere else unless it's obvious or you get up close and listen through a devise like a screw driver.
Keep us posted.
- Sadey
Agradecida
Thank you all again for the info!!
Dave & Trina
Hope it all works out. Keep us posted.
- Sadey
Agradecida
Dave & Trina
- Sadey
Agradecida
Dave & Trina
