5 mph increase dreaming
- rjr
- Vessel Info: 440 MY
- Has thanked: 25 times
- Been thanked: 9 times
We can reach 15 mph at 2250 RPMs.
Is there any way to obtain a speed increase without excessive drive train wear and to do it economically?
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: 5 mph increase dreaming
4-500 lbs of less weight won't do much, but any increase in speed is better than none at all.
- buster53
rjr wrote:Source of the post
What's your engines recommended WOT and are you getting that? 2250 sounds pretty low. A little more speed may get the boat up on a better plane and actually give you more MPG's
- rjr
I'll be that boat cruises at just north off 22 at the real cruise rpm.
- rjr
Mechanic mentioned flashing the engines. I checked with local CAT dealer - waiting to hear back. Anyone know about this?
Thanx.
- Been thanked: 490 times
The best thing you can do is clean the bottom, remove the junk from they boat, make sure your engines are tuned, make sure the props are correct for your engine fuel is good, filters are clean, and the boat trimmed correctly.
You add horsepower, you'll need different props, your fuel usage will go up, and engine life will decrease.
For example, a 350 hp 454 could go a couple thousand hours before failure.
Taking that 454, make it a 572 cubic inch engine, add a blower and make 900 horsepower, you better at least do a top end rebuild every 100 hours.
Take it to 1350 horsepower and you get allot of practice taking that engine apart every 35-50 hours.
waybomb wrote:Source of the post Please don't add horsepower or change the power curves.
++1
