Winterizing the A/C system
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
I know that if I remove the cover of the raw water strainer to add antifreeze. I will lose the prime and the process becomes a real pain.
I have a friend at the dock who tells me that he has a raw water strainer cover that has a female hose fitting incorporated into the cast. He states that this allows him to flush the system first with fresh water and then introduce antifreeze, all without losing the prime.
Unfortunately I was not able to view this 'thingamajig' before he pulled his boat for the season.
I have never heard of this and the local marine supplier has not as well.
I am interested in how you guys are going about this task.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Winterizing the A/C system
- denpooch
- Has thanked: 603 times
What I have been doing is removing the hose from the thru hull, vac out the water from the strainer, put the lid back on and holding the hose up higher than the pump with a tall funnel, fill everything and start the pump and keep filling until comes out the the hull then let the pump cavitate a bit and shut down and be prepared for the back flow.....just goes in the bilge......stick hose back on thru hull, then open the thru hull when boat comes out.
Sounds complicated huh, but really only a few minutes.that is because I like to do it before the boat comes out ( access to 120v power is sometimes an issue.
You can pump it thru from the outside drain as well after the boat is out.
This works pretty good.
- denpooch
Bud don't you lose the prime once the caps are removed? I think if I did that the pump would simply run dry. Are you 'forcing' the water past the impeller of the pump to prime?
Thank guys.
