Winterizing the A/C system
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: Winterizing the A/C system
- Has thanked: 603 times
denpooch wrote:Hans are those a press fit or screwed into the strainer? I don't believe the Algonquin strainers on my boat are threaded.
Bud don't you lose the prime once the caps are removed? I think if I did that the pump would simply run dry. Are you 'forcing' the water past the impeller of the pump to prime?
Thank guys.
I am not sure if you have the same setup with the newer boat, the problem is the unit is on the second floor.I close the thru hull and pull the hose off it and then open the strainer ( has a lid held on with wing nuts ), vac out all the water then fill to the top with anti freeze, put lid back on, hold up hose higher than the pump and insert a tall funnel into the hose and fill, once full start the pump, it will prime no problem and you continue to fill the funnel etc....takes two people and I am sure there are much easier ways, this just works for me.
The way the AC system is installed it can lose prime quite easily.it will back flow so be prepared...like I said before if you have a means of pumping the antifreeze, I believe going back thru the discharge from the outside of the boat would be OK.....
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
This may be the best route for me.
Bud, I am not able to prime via discharge, as I have tried this in the past, the idea of pumping antifreeze 'outside in' will not work with my set up.
Thanks everyone. I appreciate the feedback.
- denpooch
- denpooch
Check it out:
Users browsing this forum: No registered users and 46 guests
