Water in Bilges of 350 Mariner
- grizer
- Vessel Info: 1998 Carver 350 Mariner
Is it normal to have water in the bilges? Specifically I have around my 98 350 mariner for three years and they’re always seems to be a little bit of water in each of the bilge areas which I assume is normal. Is that the case? It doesn’t seem possible to keep the water out because someone out will always be residual left behind by the pumps. Also I always have a little bit of water laying in each of the smaller areas under each engine Where the shafts exit the boat maybe as much as an inch or 2 inches deep which does not seem to be extracted by the bilge as easily as the center area near the aft bilge. Any thoughts in these areas would be appreciated.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Water in Bilges of 350 Mariner
- mjk1040
- Been thanked: 248 times
The other areas should remain dry. If you're getting water in there you should figure out where it's coming from. It could be a leaky hose, or could be rainwater getting in somewhere. Could be the shower sump is overflowing sometimes, or a leaky hot water pressure/temperature safety valve.
- 650Guy
- Captain
- Been thanked: 40 times
Remove the engine bay covers. Along the sliding glass door under the ridge that the covers sit in, you will find a drip try. On either side of the drip tray is the drain hose. remove that and blow it out. This is a pretty common area to have water.
I think I'm going to do a new thread. I have a leak in my fresh water system and am not really sure how to access the line. Stby for more!
