Closing engine vents for winter
Sailor Jerry
Vessel Info: 1996 Carver 355
Has thanked: 2 times
Been thanked: 8 times
Postby Sailor Jerry » October 4th, 2018, 4:07 pm
I'm starting to plan to winterize my Carver 355 for the winter. Has anyone got a good way to close off the vents into the engine compartment? One year I stuffed them from the outside with foam rubber, but that was a pain. Last year I made covers out of marine vinyl with an additional thin layer of insulation, but the old snaps are worn out and it didn't seal well. I am thinking of making a wooden cover, putting a layer of foam inside and snapping it into place with spring clamps like this: https://www.acehardware.com/departments ... gKcXvD_BwE
Anyone done anything like this? Got a better idea?
Been thanked: 1180 times
Re: Closing engine vents for winter
Postby Midnightsun » October 4th, 2018, 4:17 pm
Normally the boats up here just cover them up with some shrink wrap tape. I have a roll that is 6 inch wide which I also use on all the thru hull openings. I assume you are doing this to keep critters out? https://www.ebay.com/itm/White-Marine-S ... 2853383560
Been thanked: 246 times
Postby mjk1040 » October 4th, 2018, 7:54 pm
No one here in NY covers the vents except with the shrink wrap that's on the boat?
Sailor Jerry
Postby Sailor Jerry » October 4th, 2018, 8:48 pm
I'm on the Tennessee River. Temperature will only drop below freezing occasionally. The boat stays in the water all winter, so I'm trying to keep the cold air out.
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » October 4th, 2018, 8:49 pm
I'm thinking this is to keep the cold out over the winter?
Typing at the same time :-D
Sailor Jerry
Postby Sailor Jerry » October 4th, 2018, 9:02 pm
If shrink wrap will keep the cold out, that sure sounds easy.
Dewmyster
Vessel Info: 1998 370 Voyager
Been thanked: 12 times
Postby Dewmyster » October 4th, 2018, 9:23 pm
We tape or cover them to keep the birds out in the spring up north.
:usa:
Been thanked: 646 times
Postby g36 » October 4th, 2018, 10:05 pm
I'm also on tn river on my 405 which has the same type vents as your 355. I made snap on covers that sound alot like yours that you made that matches the vents. I just used sunbrella and a layer of foam sandwiched in the middle and snap them on. Doesnt need to be air tight. Worked for 5 winters with no problems. My bilge heaters keep it warm and the covers work fine. Why dont you like what you have?
CaptBob
Vessel Info: Shopping....
Been thanked: 33 times
Postby CaptBob » October 4th, 2018, 10:12 pm
My 360 SS had covers made that snapped over the vents. Same as above, sunbrella with thin foam inside. I cut eggshell that fit the vents, snapped the covers on, Turned on the heaters and Made it through the last 4 winters that I had her here on the Cumberland just north of Nashville.
Capt Bob!
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat.... :captain2: )
Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
Users browsing this forum: Google Adsense [Bot] and 38 guests
