Wall Vac Delete
Wall Vac Delete
Postby Midnightsun » October 6th, 2018, 11:36 am
Got tired of the WallVac system most boats have. Hose was a pain, needed 110v and suction was OK at best, bags were a problem to find. Ended up getting a Dyson V7 trigger with power head. https://www.dysoncanada.ca/en/handhelds ... igger.html Works great everywhere one would need a vac suction is amazing. No cords or hose and fit perfectly under the fold up stair entering the boat where I do have access to my entertainment centre inverter plug so I can plug it in and charge no matter if I am on shore power or not. Was able to add a few panels inside and some trim outside to recoup the lost space where the wallvac was installed.
Original "Bar" hole on the left. Additional new Bar hole on the right. :-D
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Re: Wall Vac Delete
Postby pepmyster » October 7th, 2018, 7:54 am
Yes, we too removed the vac system on ours. Like you said, pita!!! Also went with a Dyson. Cleaning is now a breeze. More room for the booze that’s for sure!!
Re: Wall Vac Delete
Postby Midnightsun » October 7th, 2018, 8:25 am
pepmyster wrote:Source of the post Yes, we too removed the vac system on ours. Like you said, pita!!! Also went with a Dyson. Cleaning is now a breeze. More room for the booze that’s for sure!!
The extra compartment will actually be used to store WEED come the 17th. :-D Figure I can get it cheap at Costco. :worthy:
pepmyster
8.1 Volvo Penta
Fresh water boating
Re: Wall Vac Delete
Postby pepmyster » October 8th, 2018, 1:22 pm
Ha!!!! Somehow I can't picture you tokeing on a joint!!!!!!!!!
