360 Sport Sedan Bridge removal 2003 (or 04)
camelot
Vessel Info: Carver 360 SS
Been thanked: 2 times
Postby camelot » May 19th, 2014, 11:53 am
Hi All -
I am not QUITE a Carver owner yet, but set to do a Sea trial on a 2003 360 Sport Sedan this week. If all goes well, I own it on the spot and I will need to remove bridge and truck it to the St. Croix River. My question is: does anybody have any helpful hints, best practices, or just good advice you could share on this particular procedure on this particular boat?? ? I have hired a crew that has done a lot of bridge removal/reassembly, but I just wanted to be armed with as much info as possible since every boat configuration is different and want this to go smoothly.
Thanks in advance!! Here's to a great summer on a Carver!
Past Commodore 2016
Wild River Yacht Club
St Croix River - Hudson WI
Ramsport47
Been thanked: 59 times
Re: 360 Sport Sedan Bridge removal 2003 (or 04)
Postby Ramsport47 » May 19th, 2014, 12:18 pm
One note of advice...don't let them cut ANY wires. All f Carver's wiring has quick connect plugs and are all labelled. Cutting would make reassembly REALLY difficult.
Kenny
T-Merc 350 Mag MPI (300hp)
camelot
Postby camelot » May 22nd, 2014, 1:06 pm
Thanks Kenny - I appreciate the feedback.
It sounds like just the throttle and steering cables are the only part that is not plug and play...
Past Commodore 2016
mcgedb
Postby mcgedb » May 11th, 2016, 10:07 pm
I am curious if you bought the boat and had it transported. I am a new owner of a 2004 Carver 360 SS and need to transport it and remove the bridge. I was curious about your experience. I was hoping to do the job myself with a few friends.
camelot
Postby camelot » June 20th, 2016, 12:56 pm
Hi mcgedb - sorry I just saw this post.
Yes - bought the boat, removed the bridge and put it all back together - I had the help of our Harbormaster from my marina, but it was fairly straightforward - just a lot of screws around the inside and a few on the back above the sliding door - and everything except for the throttles were unpluggable. Came back together great - very tight exact fit - the screw holes all aligned in the first try! Let me know how your project is going or if you need and specific advice!
Past Commodore 2016
