New 88 Mariner
- rsims62
- Vessel Info: 1988 Mariner 28ft
- Has thanked: 13 times
New 88 Mariner
Getting back to weekender boats... HAd a few smaller and One Bayliner 27ft years back, Also have a 18ft Bass Boat.
Picking up a 88, 28 ft Mariner tomorrow.
I'm trying to look up the correct model number.. But not having any luck..
CDRJ9079f888 is that correct? Title didn't show the MODEL!!
Has Twin 305 in her, One runs the other won't start at this time.
Look forward to discussions...
Rob
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
Re: New 88 Mariner
2022 Stingray 182 SC
- Has thanked: 469 times
- Been thanked: 1765 times
Re: New 88 Mariner
The number you provided is the hull number, the Vehicle Identification Number unique to every vessel if you will. Hopefully someone with the same vintage boat will chime in.
What is the engine doing/not doing? Does it crank over? Not cranking, no click, nothing?
- Has thanked: 598 times
- Been thanked: 1281 times
Re: New 88 Mariner
Here...https://carveryachts.blob.core.windows. ... ger_89.pdf
- Been thanked: 646 times
Re: New 88 Mariner
Manufacturer
GENMAR YACHT GROUP LLC*
HIN
CDRJ9079F888
Model Year
1988
Serial No
J9079
- rsims62
Re: New 88 Mariner
One engine was water damaged. The other would turn but not start. Owner didnt know too much about it.
I got it to use mainly for Weekend at the Marina, I have a Bass boat and another runabout, so If I can get the one running it would be nice to have.
Ill be messing with it once I get it to my slip..
I need to check the bilges out, Today I switched the one on and it worked, The AFT one was not working, couple of taps and it ran, Then it Stopped, still water in there, I went and tried the Other bilge and nothing, WHERE are the Fuses? or breakers?? I tested for power and none at either wires??? I might have over loaded something, the panel its on has other things and they still work. Maybe they died but no power to the wires has me confused.. I checked the fuses at the aft deck, as you walk out and they were good?
Going tomorrow to see whats what
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
Re: New 88 Mariner
- rsims62
Re: New 88 Mariner
I tested the pumps with power and they work.
So I know a loose wire or broken wire would do this, BUT to all the bilge pumps, Something else had to happen here? they had power and then everything stopped, So I must have a fuse somewhere blown, I checked all 3 battery fuses and they are good, Everything else on the Panel works .
Rob
- Been thanked: 601 times
Re: New 88 Mariner
Re: New 88 Mariner
