Oxidation Build Up In Distributor Cap
- mjk1040
- Been thanked: 248 times
- Has thanked: 603 times
Re: Oxidation Build Up In Distributor Cap
...I'm kidding......clean up good, vac it out, if there is a vent screen make sure it is not plugged , inside there needs to breath , make sure you have the gasket in place and marine cap, the gasket will set the correct height for the cap and rotor relationship.... do not seal the cap. You can spray but really if it is clean and checked every now and again you will be just fine.Are you going to change the ignition modules as well ?
- mjk1040
Remove the wiring plugs from the module and check the contacts for corrosion. With compressed air either from a compressor of aerosol can, give the components a blow. Also, always check the gap on the spark plugs and set to spec before installing them.
- mjk1040
Ya those are bad.mjk1040 wrote:Source of the post Geez Viper the rotors on an EST can't be as bad as those ones Mercrusier uses on the tapered shafts and takes 2 pry bars to get them off.
