Define CLF code in laymen's term
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- mjk1040
- Been thanked: 248 times
Re: Define CLF code in laymen's term
- Cooler
- Has thanked: 603 times
- Cooler
I assume you're getting good raw water volume out the discharge?
- mjk1040
- Cooler
viper - thanks for the evaporator info. I believe the unit is mounted under that galley counter top. Have to figure out how to access to check that evaporator out. That could very well be the issue because I know the previous owner never looked at that unit. Chances are, the unit was not cleaned since new. When I had water coming out of the discharge during cooling, it did seem to be a good volume. When the CLF code is on, no water. When the heat is on, the discharge seems fine and normal. Thanks all!
Any advice on how to access unit?
There is a high pressure switch on the output side of the compressor. If the water flow is clogged, then the temperatures in the freon go way way, and the output pressure on the compressor goes way up. Eventually it would lock up the compressor, so there's a high pressure switch on the output side of the compressor. This will open up, shutting off the compressor. There is also (usually) a temperature-sensative breaker mounted directly on the compressor. If the compressor gets too hot, then this will open up shutting off the compressor..
Usually the high-pressure switch will trigger it's own fault code and you will have to reset it to get the A/C unit to work. The temperature breaker (I want to say it's called a "Klixon" but I may not have that spelled correct) will reset itself when it cools down.
Please note, this info is based on knowledge of commercial heating / cooling systems, NOT the marine airre, but it should help.
The control looks for amperage of between X & X (differs depending on unit size) when the compressor should be running if no or low amperage, you get a CLF fault, if over amperage you get a HFC fault. Codes may differ depending on manufacturer of control board.
Sooo, I believe you are drawing low or no amperage. Does your compressor run? If so you are most likely low on refrigerant. if not either the compressor is bad, or if your lucky the start capacitor.
Good luck.
