battery management switch
Re: battery management switch
tomschauer wrote:Source of the post .....Without 120 volts, the battery charger should not do anything. Are you sure you don't have an inverter and are using the batteries for 120 volt loads? That could drain your batteries quite fast depending on what you are running...
+1
That's why I asked earlier if there was an inverter or some other device hooked up that triggers a low voltage alarm. I haven't come across any typical chargers that do that.
We also still don't know the battery specs which makes a huge difference. Are they 24, 27, 29, 31? What is the spec/capacity? If they are cheap 24s for example and the fridge is original, ya I can see a problem. Need some things confirmed/questions answered so opinions offered aren't based on assumptions.
- SkyeToo
- Vessel Info: 1989 36' aft cabin, galley down
full upper and aft deck canvas - Location: Ontario Canada
- Has thanked: 6 times
- Been thanked: 4 times
happy 2019 and great boating season to all.
bruce
- SkyeToo
As others have tried to explain, you don't really have a house and start bank. The battery selector switch powers both house and start loads with whatever bank is selected. Soooo, when switch is at 1, all 12 volt loads are powered by whatever batteries are connected to that side, including the engines. Same with the other positions.
Well... there are 2 deep cycle batteries (brand new, marina installed and tested) and a brand new starter batter. So not sure what you mean that I don't have "a house and start bank". and yes, "1" should be engine start, "2" house only. What I have not clearly determined is which batteries are connected to which side of the switch. Reading the Perco switch manual, it seems evident that the engines should NOT start if the switch is in the "house" position (can be wired to either 1 or 2 obviously). Meaning, there should be no connection from that battery to starter motor in that case. "All" is, well.. all. no issue.
I am beginning to think that the fridge may be part of the problem cycling too often on DC.
What am I missing here?
Bruce
- SkyeToo
Thanks again.
Bruce
- Has thanked: 603 times
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Bruce[/quote]
When you have a single battery switch, that switch controls all DC loads, both engine starting and house loads. So, if you have it in position 1 the batteries connected to the #1 line side of the switch power all of your DC loads, starting and house. If you have it in position 2, any batteries connected to the #2 line side of the switch controls all DC loads. With a single battery switch, your engines and house are not segregated on the load side. With what you have you would want to start on the #1 position and switch to #2 when not starting or running. To isolate the engines from the house you would need to change the load side wiring on the switch. This would leave you with no house power at all when switched to #1. To do it properly you would need to add second battery switch (preferred) or direct wire the starting battery to the engine starter leads. If you do this (direct wire), you don't have the ability to use the house batteries to start if needed or to have the alternators charge the house batteries if needed.
- Cooler
SkyeToo - I doubt your switch or fridge is bad. Engine starters are connected so they will start with either position on switch accept for Off. You are on the right path, trying to determine which batteries are connected to which switch position. Hopefully you can see which battery terminals are ganged together, then put all deep cycles together on one position. Put starting batt on the other position. Try turning on a couple of lights in the salon, because they should turn on in one position or the other, and ALL, both not either position, if the wiring is correct. Here is that link you were requesting, but there is no wiring diagram. https://carveryachts.blob.core.windows. ... m-boat.pdf
- Cooler
