Screws coming loose from trim tabs - Uh oh!
- Seif911
- Captain
- Vessel Info: 1977 Carver Mariner 33'
- Been thanked: 4 times
So my Carver is still stuck in my yard because it won't stop raining and it is like a lake. I am thinking that I have enou time to address a possible nightmare with the trim tabs. On each tab, there were 3-6 screws that have backed out. When I screw them in, they spin. I tried a bigger screw and it worked for some but not others. Thoughts?
I know the obvious concern about the core being possibly wet...I am praying it isn't! Thus far, when I thought the Carver was going to the water, I filled the hold with 5200 and put the screws back in. Now that I have time, what should I do? Should I pull the trim tabs off, open the holes up, fill then up with fiberglass resin and then red rill them and put it all back together?
Any thoughts? Any process better than I mentioned? Should I just leave it alone?
Thanks All,
Steve
Steve
- Has thanked: 64 times
- Been thanked: 481 times
Re: Screws coming loose from trim tabs - Uh oh!
Me, I'd remove one, and inspect the holes. If the wood is wet, dig a little out and see if you can get to dry. If so, then it's time to brush up on fiberglassing skills!
And when all done, I'd through bolt with a backing plate and seal with 5200.
- Seif911
- Captain
I agree it will not get better. I suppose I will have to dig into it, literally. This is probably the scariest problem I have had this far.
Steve
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
