Question on overheating repair or replace
Re: Question on overheating repair or replace
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
- 390Express
- Captain
- Has thanked: 141 times
- Been thanked: 15 times
I always considered a small amount of steam in the exh normal. A 6 degree temp difference wouldn't bother me at all.
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
Here are my next steps.
1) I will disconnect the other raw water hoses from what looks like a fuel cell, and also from the other side of the heat exchanger to see if any debris falls out.
2) The heat exchanger is up tight against the exhaust hoses on both sides. Would it make sense to use Rid-Lyme on it now before I start pulling the heat exchanger apart? I will use the sea flush system that I use for winterizing and that will tell me whether I am still having the same problem with the water flow. Looks like some work to get the heat exchanger removed and since Cooler mentioned that pulling those hoses is a tough job, it may not be doable to get the ends of the heat exchanger off without pulling the HE or removing the exhaust hoses.
As a reminder the flow was restricted when I used the Sea Flush system to winterize. Took a very long time to get 5 gallons through it. Spitballing here, could it be something to do with air being in the system? Seems like it began happening at the start of last season.
- Helmsman
Viper wrote:Source of the post I wouldn't worry much about the exh. manifolds if she's a fresh water vessel unless further diagnosis takes you in that direction. You could have garbage or impeller pieces from a previous failure in the HE or cooler though. Impeller pieces have to be removed manually or flushed out but try Rydlyme to descale and clean the HE and cooler before removing and sending out. Of course check all the other normal things like intake hoses, connections for leaks, strainers, seacock, etc.
I noticed the slow flow last fall when I was winterizing with a sea flush unit. So the seacock and strainer are ok I think.
If you are in the water, did you start the engine and check for flow? Fire them up, both should have nearly equal flow out of the exhaust. If not, you have something in the system. I would doubt its scale. You usually only need to use a scale remover if you have good flow and still cant transfer the heat. Scale removers can soften the copper of your heat exchangers, only use them if needed. So, unless you are in an area with zebra mussels, it most likley impller pieces somewhere in the system.
- Has thanked: 602 times
- Been thanked: 1310 times
Nharrison5 wrote:Source of the post
I think I would still remove the hoses and have a look before treating.....if by air, you mean the system is pulling in air.....yes that is possible and will screw with your flows......check all your hose connections, especially the ones you remove often on the suction side, could be a small crack at the pump inlet, been there done that, they don't necessarily leak when off making it hard to find.
I cant remember but you have checked the thermostat ?
- mjk1040
- Been thanked: 248 times
- Helmsman
bud37 wrote:Source of the postNharrison5 wrote:Source of the post
Bud, I haven’t checked the thermostat. I know I have low flow. When I winterized the system with the Sea Flush kit, it took much longer to pull 5 gallons of AF out of the bucket. Also, when I started it yesterday, the flow out of the exhaust was lower than the other engine.
- Helmsman
mjk1040 wrote:Source of the post I noticed you had an issue getting hoses off. A heat gun is a must when trying to remove hoses IMO. Viper mentioned earlier to descale the engine with RydLyme! And as mentioned thermostats.
Thanks. Great suggestion!
