Shaft Packing Leak?
VicB
Vessel Info: 1988 Carver 3807
Has thanked: 41 times
Been thanked: 11 times
Shaft Packing Leak?
Postby VicB » January 15th, 2019, 8:20 am
I have an 88' 3807 with twin Crusaders. As I am new to having a boat like this, i have been crawling over her almost every weekend, trying to get familiar with all the systems, so I can be familiar with everything I can, come boating season. One thing I have noticed is that the packing from each gland where the shafts go through the hull drips a drop about every 5 seconds. Is this normal? That equates to pumping out about 5-7 gallons of water every week or so. This always leaves water in the keel as well. Has anyone every replaced packing while in the water? I am thinking i will see if i can tighten it some this weekend. I think the shaft is 1-1/8". Does anyone know packing size?
Thanks in advance,
Vic
Re: Shaft Packing Leak?
Postby g36 » January 15th, 2019, 9:34 am
You'll need 2 wrenches to tighten it. some drip is ok depending on type of packing. And yes packing can be changed while boat is in water. Not sure of the size of yours
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » January 15th, 2019, 11:52 am
VicB - that shaft size looks a little thin for that model. At the end of this message is a link to 38AFT spec sheet. That discloses a 1 3/4" shaft. I don't know if shafts have been replaced with a smaller diameter but that would be unusual to say the least. If you have the owners manual and OEM list, you can find the specs in there. OR, you may want to call Carver with your hull # in hand. They should have the info for your particular boat. While that drip is not unusual, it is probably dripping more while the shafts are turning. I have a 330 Mariner, 1 1/4" shafts on V Drive. I do not drip at all, parked or running. That adjustment is a little tricky so be careful, instructions are in your owners manual.
https://carveryachts.blob.core.windows. ... bin_88.pdf
Cooler By The Lake
VicB
Postby VicB » January 15th, 2019, 12:23 pm
Cooler,
You are probably right. I measured them a while back and since then, I have done so much in that engine compartment that I would bet you are correct and i have my numbers confused. Last night i ordered 1-1/4 hose and all week i've called everything 1-1/4. I've got to quit watching so many Youtube videos. It all starts running together.
Postby bud37 » January 15th, 2019, 1:34 pm
If you do decide to snug them up a bit, a good tip is to loosen first to flush a bit then tighten accordingly. I believe the packing manufacturers have charts to show the proper packing sizes for the different shaft sizes and packing gland designs.
Been thanked: 491 times
Postby waybomb » January 15th, 2019, 5:42 pm
Inspect the threads - one side is righty, other is lefty. You also may need a big honking wrench to loosen the jam nut.
Postby km1125 » January 17th, 2019, 6:39 pm
I'd have sworn I already commented in this thread, but don't see anything.
I have a 3607, so a similar but slightly smaller boat. I have 1 3/8 inch shafts.
I used these wrenches to adjust the packing. I got them from home depot and they aren't that expensive (and handy for a LOT of other things too). Get two and you can also use some short lengths of pipe if you need more leverage. Also, as waybomb notes, check the direction of the threads to make sure you're turning the right way or you'll never get things loosened up!!
Cooler
Postby Cooler » January 17th, 2019, 8:46 pm
Nice tool! ( she said ) Gotta go to Home Depot!
Careful when adjusting, too tight can create heat. Heat creates burn. Burn creates $$$. It is normal for standard shafts to drip a little while running. Some don't, but most do. 8-) er
Cooler By The Lake
Redemption
Vessel Info: 1982 Carver 3607
Postby Redemption » March 22nd, 2024, 6:49 pm
I wish I had that wrench yesterday. :lol:
