Yellowed Panel on 390 CPMY
- Has thanked: 603 times
Re: Yellowed Panel on 390 CPMY
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
https://www.davisinstruments.com/product/fsr/
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
SplashyLady wrote:Source of the post You should find the Interlux Brightsides Off-White Poly (4381) to be a very close color match. Don't use the Hatteras Off-White - it's a little too beige. This paint has nice gloss, flattens well, and you and apply it with roll and tip, foam brush, fine brush, or spray. The match is surprisingly good on my Carver.
How did you prep? I was thinking of sanding with 220 paper at first. Then did you use a primer? I would assume a sanding of the primer with maybe 400 grit? Then a coat or two of paint? Thanks again for the info!
- Been thanked: 654 times
- tonyiiiafl
I would get a new sheet and replace it. Project complete for the next ten or twenty years.
