Interior Carpet
- Been thanked: 1177 times
Re: Interior Carpet
- Been thanked: 601 times
Re: Interior Carpet
- Has thanked: 467 times
- Been thanked: 1759 times
Re: Interior Carpet
650Guy wrote:Source of the post Oh man! I did not even THINK of the glue part! So I’m assuming it’s glued, but how do I determine what type it is?
I would recommend contacting Carver and asking what they use, then try and find out its formulation. That'll give you the information you need to know when buying the new stuff.
You'll need a glue that will adhere both to carpet and fiberglass if that is your substrate. Also get a glue that will hold up for exterior use as it has benefits such as the ability to put up with humidity, cold, water, etc. And look for a glue that is low VOC so that off-gassing isn't harmful to your health in such tight quarters.
- 650Guy
- Captain
- Been thanked: 36 times
Re: Interior Carpet
- Cooler
- Has thanked: 68 times
- Been thanked: 405 times
Re: Interior Carpet
jbroder@marquisyachts.com
- 650Guy
- Captain
Re: Interior Carpet
I had not considered overlaying the carpet. It raises an interesting idea. I’m just dumb enough to start tearing out the carpet, get 1/2 way into it, regretting it... but being committed now! LOL!
Re: Interior Carpet
- 650Guy
- Captain
Re: Interior Carpet
- 650Guy
- Captain
Re: Interior Carpet
“Jeff has transferred to another department, so his emails come to me. For the glue, we typically used a basic carpet glue that would have been troweled out on the floor to attach the carpet. Most carpet stores carry it for glue in carpet installations. We also would occasionally use silicone to glue in the carpet. The installer would have used a caulk gun to lay a few lines of silicone on the floor and then lay the carpet on it. It was never recorded as to which method was used on each individual boat, so I could not say how this one was done specifically. You will also find that on the ends of the stairs, around the hatch openings and on the hatches themselves, there would have been staples also used to attach the carpet.“
- Cooler
Re: Interior Carpet
