396 ES TV amplifier/power supply
- DanM
- Vessel Info: Carver 396
- Been thanked: 34 times
Carver 396
SugarSand Tango
- Has thanked: 598 times
- Been thanked: 1281 times
Re: 396 ES TV amplifier/power supply
- Been thanked: 601 times
- Cliffm
"the Condo"
- Has thanked: 260 times
- Been thanked: 20 times
There was in Wall outlet inside this cabinet that teh TV was plugged into as well as the amplifier for the Arch TV antenna.
Hope that helps narrow down your search area.
- DanM
Carver 396
SugarSand Tango
If you dont mind, did you just use the existing cable to join the new antenna to the amp etc ?...Thanks .
- DanM
I used the existing cable but cleaned the connecters with a brass wire brush. They cleaned up very nicely but be sure the power to the amp is off so you don't short it out. I connected the amp to power using the supplied 110 wall-wart transformer. Same as the previous installation.
Carver 396
SugarSand Tango
