7.4L TBI fuel pressure problems
- 390Express
- Captain
- Has thanked: 141 times
- Been thanked: 15 times
Re: 7.4L TBI fuel pressure problems
Make sure you clean your flame arrestors, use the proper heat range spark plugs, have good wires, and if pressure, & octane are both good (run at least 91) look into replacing your injectors. I bought brand new BW injectors for around $90 each. (Brand new BW fuel pump for around $90 as well, I ditched the pierburg fuel pump, but it wasn't the issue) If replacing your injectors doesn't work, I would look next at your distributors. I think that is my problem. My port motor distributor varies in timing around 2-3 degrees at 3k rpm (bounces around slightly), my starboard motor (my problem motor) varies around 8-10 degrees. I'm replacing at least one distributor before spring. They're fairly inexpensive ($120ish per side, brand new).
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
- mjk1040
- Been thanked: 246 times
On another note as to the TBI's, pull the air control valve and clean it or replace it. This may be the issue!
- Cooler
er Note: we are getting a 12 - 14 inch snowstorm right now. Coming your way. Come on spring!
- 390Express
- Captain
- Newer boater
- Vessel Info: 1991 3608 aft cabin
- 390Express
- Captain
Newer boater wrote:My mercruiser wrench said if I used non ethanol gas I would need his services a lot less. Lucky for me the marinas here all have rec fuel. On the dock it’s 3.95 a gal.
$3.95 is great. It was around $4.65 - $4.85 for most of last year up near St. Clair Shores.
Users browsing this forum: Google Adsense [Bot] and 16 guests
