towing RIB behind 3607 Carver
- racerrick
- Vessel Info: 1986 3607 Aft Cabin. Berthed Palm Island Marina, Cape Haze, FL
Has anyone seen, used, have knowledge of a towing rig as pictured in the attachment; it is from a houseboat forum & they go slow. We usually cruise at 12+kts. RIB is a Novurania 11.5L X 5.5ft.B, weighs 571 lbs. dry total including 197 lb. 25 hp Yamaha. I plan on using the existing typical Weaver Snapdavits on the swim platform as the pivots, hoist it with a winch or block & tackle & secure it with rigid stand off arms from the towing ladder arms to the stand off arm brackets on the transom plus the hoist cable. Probably attach the winch or block & tackle to one of the aft deck vertical stanchions. I'll get some exact measurements including angles & find a mechanical engineer to do a force analysis so I can check with Weaver & make sure the Snapdavits & standoff brackets will carry the load plus a substantial safe margin. That will be an interesting exercise as the amount of buoyancy at the bow partially supporting the weight will be tricky to determine. I'll have a stout cover fabricated to prevent shipping water underway. I've looked at roll on & typical hoist davits for a heavy RIB - cost substantially more than I paid for the RIB plus quite a lod on the swim platform I would think. There will be an issue berthing the boat. Will have to heave to, lower the boat, raise & secure the ladder & use snap davit rings on the RIB to secure it transversely to the swim platform & then proceed very slowly, as usual anyway, into the marina & berth. Won't be an issue anchoring. Any mech. engineers out there that want to take this on? I'm concerned about it bouncing in the close behind wake & forces that might transfer to the boat & attachments.
- Has thanked: 597 times
- Been thanked: 1281 times
Re: towing RIB behind 3607 Carver
- Has thanked: 76 times
- Been thanked: 1090 times
- StDuckie
- Vessel Info: 1991 3607 Aft Cabin Cummins 6BTA
- Has thanked: 29 times
- MakinTime
- Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo - Has thanked: 52 times
- Been thanked: 31 times
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
2022 Stingray 182 SC
- Bentone23
- Vessel Info: 1996 Carver 355 Aft Cabin
454 xli TBI Crusaders - Location: San Francisco Bay
- Has thanked: 57 times
- Been thanked: 5 times
- Contact:
Bentone23@sbcglobal.net
1996 355 Aft Cabin
Central California
Boating on the Delta and SF Bay
- MakinTime
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
- Been thanked: 1179 times
Users browsing this forum: No registered users and 52 guests
