air conditioner replacment
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: air conditioner replacment
- CaptBob
- Vessel Info: Shopping....
- Been thanked: 33 times
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat....
)Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Cooler
- Dymonddan
- Vessel Info: 1995 Caver 355 Aft Cabin
Thanks guys for the help and suggestions
I'll go this weekend and see if I can get a head start on it and hopefully have all I need when the new unit comes in
As others have mentioned take a look at what you have. Pretty simple, the water circulation hose that goes to the side thru hull is obviously the out line of the AC. Hopefully the ducting used by Carver was the standard 6" round at the unit which may or may not need to be lengthened to make the connection. 110v is simply swapped into the new unit and the thermostat will probably need a new wire as they all now use a telephone jack style connection/wire. In my case since the boat is newer and the thermostat wire/connector was already the correct one.
- Dymonddan
That was the same code as I was getting on mine. The a/c guy that looked at mine said the fan motor 'shorted' out and burnt the board when that happened. It would not heat or cool as the fan wouldn't run. Even when I ran the self diagnostics test it showed all was well. even showed the fan running in all five speeds although it never came on and the water pump did not come on.
- Cooler
