Was: Deck Core Thickness? NOW: Deck Replacement
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Deck Core Thickness?
BenTen wrote:Source of the post..... Is it possible for water to travel that far in the core, especially since the individual balsa blocks are supposed to be sealed from each other to isolate water leaks?.....
Definitely possible for water to wick throughout the core over time. The chances of each and every block being completely encapsulated varies. You will find that difficult to do and confirm before the resin starts setting up on you if you're doing a large area. Vacuum bagging during the manufacturing process helps the resin reach all areas but it really depends on a few factors. Make sure you get "endgrain" balsa core, and wet it out properly to ensure penetration.
Don't cover the mounting holes or the chain hole with balsa then drill and cut it out later. If you leave a 1/4" clearance around these areas then fill them in with a thickened mix, you will never have exposed balsa. For the chain hole, putty up to the original cutout. For mounting holes, fill them in completely with the putty then drill through the putty for mounting the hardware when the job is completed. This way, you're drilling into a solid plug of glass or epoxy rather than your core and exposing it all over again. This also serves to prevent you from crushing the core if you over torque the fasteners as the substrate in that area will be a solid mass that won't compress. And if the seal around the fasteners fails, water can't get to the core as there will be a 1/4" of glass or epoxy in the way. ALL hardware fastened to any areas of the vessel that have coring material should be done this way. I also rarely use caulking for bedding or sealing fasteners anymore, I opt for butyl tape. I've posted procedures in a couple of threads for proper fastening techniques and the use of butyl tape.
- BenTen
- Vessel Info: 1984 Carver 3697 Mariner - "We'll Sea"
- Has thanked: 20 times
- Been thanked: 32 times
For anyone searching in the future I can tell you these things so far on the 3697's:
1. To access the deck rail and cleat hardware you must remove the interior "valances" (not sure if that's the correct term) that are installed in front of all side windows, along with any blinds or curtains. To do this you should be able to locate a phillips head screw approx every 18 inches or so. Once these screws are removed, and the valance is hanging, there will be wiring to the lighting fixtures above the settee and dinette.
2. The deck hardware used is a washer and nut only with no backing plates so you need two people to remove these (stanchions, cleats, etc.)
More to come as I continue to dig in!
Ben in SC
- BenTen
Ben in SC
- BenTen
And a few hours later- the deck in this area is removed and the sopping wet core disposed of.
I put down double sided tape around the perimeter and covered this area with plastic until I could continue working.
Ben in SC
Re: Was: Deck Core Thickness? NOW: Deck Replacement
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- BenTen
Cooler wrote:Source of the post Yes sir. Great job! Keep posting pics with your progress. What are you going to use for replacing the balsa?er
Going back with the same 1" balsa that I was able to source from Defender.
Ben in SC
Users browsing this forum: No registered users and 37 guests
