Head vent blowers on Voyager
Viking-boater
Vessel Info: 2006 Voyager 46 GS. Volvos D9-500 HP
Postby Viking-boater » September 25th, 2018, 10:54 am
Have a 2006 46 Voyager and the starboard head exhaust blower is very noisy and needs replacement. All trim in that area is glued and no screws to be seen. Anyone’s help would be appreciated before I start with a crowbar and maybe damage areas where it is not located.
Has thanked: 469 times
Been thanked: 1765 times
Re: Head vent blowers on Voyager
Postby Viper » September 25th, 2018, 3:01 pm
Welcome aboard. Hopefully someone with a similar model and vintage will chime in. Nice boat by the way :down:
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » September 25th, 2018, 7:03 pm
Welcome to the forum....here is a pic of the blowers in a 2005 450, the blower itself appears to be in a different location...check it out may be like yours , I dont really know.........section 16.2
https://carveryachts.blob.core.windows. ... ual_05.pdf
Been thanked: 468 times
Postby RGrew176 » September 25th, 2018, 10:43 pm
Welcome Aboard. Lots of knowledge here for we Carver owners.
2022 Stingray 182 SC
Postby Viper » March 12th, 2019, 10:24 pm
V-B, did you ever figure this out?
Viking-boater
Postby Viking-boater » March 12th, 2019, 10:40 pm
No. I guess it will be crow bar and hammer time.
Postby Viper » March 12th, 2019, 10:48 pm
I find an easy way to "cut" glue under something is to get some fine wire like mechanic wire, start on one end and get it behind the item you want to remove so that an end of the wire is sticking out of both sides, then pulling the wire down the length of the item. There are several things you can use but I always have thin stainless steel wire on me that I use for other things. Works great. High test fishing line should work too.
Postby Viper » March 13th, 2019, 6:25 am
It would also help if you contacted Carver with your hull number and let them know what you're trying to do. The trim may be snapped into place mechanically or there may be another access point.
