Prop Question
- fleck05
- Vessel Info: 1983 Carver 3607 Aft Cabin
- Has thanked: 20 times
- Been thanked: 4 times
- Contact:
Prop Question
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Prop Question
- Has thanked: 78 times
- Been thanked: 1093 times
Re: Prop Question
I have the same boat ('83 3607). Several years ago I ran through some mud and damaged both props. One was badly curled down about 1/2", but the other wasn't much better. The prop shop was able to get the prop back to original specs and matching the other prop. I had had both props scanned and adjusted a few years before that, so I had really good "before" specs. They were able to return the props to those specs, and it cost me $733.10 (but I also got a $183.27 discount for being a repeat customer, as it was the same shop that did the original tune-up).
In the meantime, I used a set of spares I had purchased from a local guy. They were slightly smaller but since I don't cruise at WOT, it didn't matter much. I put the original set back on over the following winter. My spares cost $300. Deals are out there if you're patient and flexible with the specs. I've already used them twice and it's great to just haul the boat, put the spares on and drop it back in and then have the rest of the season to get the mains repaired and ready to put back on in the off season.
I would definitely not file them down. You could easily end up with an imbalance situation, with either weight, pitch or diameter that will cause vibrations. If the edge is not survivable, and good prop shop could cut the diameter of both props down by the equivalent amount.
EDIT - I went back and looked and they did take 1/2" off my props. They were originally 22" diameter and now they are 21.5". Mine are originally 22x22 props. You have 23"? What engines and reduction gear do you have?
- fleck05
- Contact:
Re: Prop Question
It is on land now and for 7-10 more days. I am looking for a used prop, but am always impressed by the years of experience in the responses here... this was just for me to get some additional info from outside local opinions.
I’m in Key West right now and it seems like used props would be easy to find, but this is essentially a small town so there aren’t a lot of resources. I’m also searching online. If I were closer to Tampa I’d go to that large boat part pulling place, but cost of transport there would not be worth it.
If anyone knows of a used 22-23 inch prop for the starboard side with a 23 D pitch for a 1 3/8” driveline I’m interested... text me at 619-753-1285
- fleck05
- Contact:
Re: Prop Question
EDIT - I went back and looked and they did take 1/2" off my props. They were originally 22" diameter and now they are 21.5". Mine are originally 22x22 props. You have 23"? What engines and reduction gear do you have?”
Ah, that makes total sense, and the fact you did the same thing with a Carver 3607 is even better. Yes, they are 23” props, and the boatyard found a set of less expensive prop at 22” they said would work ($1500). We have TAMD 60 Diesel engines by Volvo Penta. (As a side note I’ve been impressed with the performance of the engines, but any part with the name Volvo Penta is 2-3X more expensive... something I’m sure is old news to all of you, lol.)
So far I’m only dealing with the local boatyard, very nice people, just looking for ideas and input from this group full of people who have “been there, done that,” for some opinions from people not trying to sell me something. I’m going to have a talk with a prop shop. Thank you.
- Has thanked: 64 times
- Been thanked: 481 times
Re: Prop Question
And then send yours out for repair, or get another set on ebay if cheaper.
I bought spare props for my 4207, 3697, and stainless cleavers for Plain Vanilla.
All of them way cheaper for each set than even one new prop from a prop shop.
- fleck05
- Contact:
Re: Prop Question
I’ve been searching eBay, but yes - an alarm is the way to go. In fact I’ll keep it on from now on, too. If a deal pops up on a prop it’s always handy to have a backup.
Re: Prop Question
- fleck05
- Contact:
Re: Prop Question
Had a prop guy in business with 20 years and good reputation in the Keys come by... I asked if the prop is good for anything and (after explaining why in detail) the bottom line is it's good for yard art, that's about it. I couldn't find many 23" props, and none for 1 3/8" driveline. We're biting the bullet and getting a match set of smaller props - they're a little less expensive and after reading nightmare stories of bent driveline repairs and strut problems, a good set of props are probably the right investment. We are going to sell our good 23" port side prop and a 23" spare port side that came with the boat to help offset the cost (damaged prop was starboard side, didn't have a spare for that one). Thanks for the input.
- Been thanked: 601 times
Re: Prop Question
Usually the larger diameter, the better the "bite". Someone can correct me, but I would rather have a larger diameter and less pitch for better bite and efficiency.
