shore power
- fishtales
- Vessel Info: 1981 Monterrey
shore power
Re: shore power
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: shore power
Re: shore power
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Re: shore power
If your boat has a generator, you should have an automatic relay that will switch from generator to shore power, as a safety, so you never draw power from both.
On a number of occasions on my 356, I used the generator and when I shut the genny down and switched to shore power, it did not work. The problem was the relay did not trip over to shore power as it was stuck.
I corrected the problem with a slight hit to the face of the panel with the side of my fist. It knocked the relay free and the shore power was able to connect to the panel again.
If this is the issue, you should get that replaced or give it a knock if it happens again what ever you happy with.
Just a thought.
Re: shore power
Only 1 post on March 28th the same day he joined asking about a Monterey boat not that brand matters but not too many people here would be familiar with the electrical setup on it. Be more than happy to help but a little feedback to know you are still around would sure help.Who is online
