...Please don't use tape. Use heat shrink adhesive lined connectors. Bilge pump hardware and its circuits fall under a critical system category and should be wired accordingly. You don't want there to be any chance of corrosion or the connections coming in contact with dirt, mold, water, moisture, condensation (Winter/Spring), etc. They don't just seal the wire, the insulation and adhesive also serve to stabilize the connection. High or not, when something fails and water starts to rise, the last thing you want to worry about is whether the circuit's wiring is going to continue doing its job while submerged. If the wiring fails, all the new pumps and float switches won't help you then, and while the connection point might be the cause, there's no guaranty that that's where the wire will fail, and trying to find where along the wire the failure occurred can take hours...not a good thing during an emergency.I don't carry anything but heat shrink adhesive lined connectors anymore. They're a little more expensive but in the grand scheme of costs to operate a boat, they're cheap insurance.
......great for strain relief on the wire joints just not personal strain relief afterwards....
