2005 444 Aft Cockpit - Fuel Consumption
petergbolton
Vessel Info: 2005 Carver 444 Aft Cockpit
Has thanked: 8 times
Postby petergbolton » March 30th, 2019, 8:28 pm
We have the 2005 Model 444 Aft Cockpit. Does anyone with the same model Carver have accurate fuel consumption figures. Specifically, both engines at 1000 rpm, 1200 rpm, 1500 rpm etc. Not so interested in speed, just gallons being consumed as a total both engines. About to start the Loop etc etc!
Re: 2005 444 Aft Cockpit - Fuel Consumption
Postby bud37 » March 30th, 2019, 9:22 pm
What engines do you have ?
petergbolton
Postby petergbolton » March 31st, 2019, 7:34 pm
Volvo D6's, 370HP each.
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Postby buster53 » March 31st, 2019, 10:33 pm
Don't have your boat or know your engine's fuel consumption. That being said, if maximum range is your goal, keep your speed at hull speed or less, about 8 knots. Anything above hull speed and below a decent plane, you will be wasting lots of fuel.
Postby Midnightsun » April 1st, 2019, 5:33 am
This will give you a very good idea of what to suspect. http://www.boat-fuel-economy.com/outboa ... us-gallons
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Postby Tireless » April 2nd, 2019, 6:22 pm
petergbolton;
I have a 2006 44 CMY with the Volvo Penta D6 engines. These are some figures that I noted in the short time I have had the boat. I will give it you in US gallons. This is from my EVC for both engines.
1,000 RPM 2.5 GPH
1,500 RPM 6.9 GPH
2,000 RPM 13.8 GPH
2,500 RPM 18.2 GPH
3,000 RPM 25.8 GPH
3,600 RPM WOT - 34 GPH
The running joke among my friends with diesel engines is that when you run these things at about 7-8 knots, they almost make their own fuel. Have a great trip.
petergbolton
Postby petergbolton » April 2nd, 2019, 7:53 pm
Exactly what I was looking for. Thank you!
Tireless
Postby Tireless » April 2nd, 2019, 9:14 pm
Just an FYI. When I run across Georgian Bay on plane, as you may consider outside inner coastal waterway, I run at 3150+- RPM’s. that would be you pocket for your best time, distance, fuel consumption ratio. Gives you about 20-21 MPH. You may want the put a fuel conditioner in the fuel for better performance, I use Stanadyne. Lee’s everything clean and improves fuel consumption.
