‘01 356 with Cummins
- thp1957
- Vessel Info: 2001 Carver 356
Cummins Diesels - Location: Minnesota
Does that sound correct? It’s going to be a couple weeks before the wrap comes off so I can get in the boat and I’d like to get new filters ordered.
Re: ‘01 356 with Cummins
When you do the oil change, check the condition of the oil. If you're up to it, open up the filter and look for metal filings. This will tell you if they've ever been serviced before. They should have been replaced after about 25 hours as part of the new transmission break-in period. Filings at that time is normal. If you see filings now, the filters weren't changed or it may be a sign that something is going on internally.
Yes they are washable as they consist of welded mesh and perforated steel. In my case I ordered 2 and replaced the existing ones which I brought home and cleaned up 100% ready for swap out again next time around.
