Proper prop selection for 466 MY in Fresh water?
carvergofast
Topic author - Scurvy Dog
- Vessel Info: 2001 Carver 466 MY
I have heard that you may have to drop two pitch sizes to achieve the proper WOT. If anyone has input on this I would sure appreciate it. Also FYI, I am running the Volvo 74 TAMD's
480 HP, and they appear to be running well. Thanks
- Has thanked: 64 times
- Been thanked: 481 times
Re: Proper prop selection for 466 MY in Fresh water?
And what about the fuel you are now using - is it the same as what you used to use, or does it have a different emissions package?
After that gets all sorted out, call a prop shop. They'll give you a form for recording a bunch of data - rpms, speed, etc. From that, they can suggest a repitch of the prop, if needed.
Make sure your bottom is clean too. Your boat bottom.
carvergofast
Have driven the boat 4 more times since the post and no matter how I slice it, I get 23.4 GPS. engines are running great with no smoke, but lost 250 rpm from saltwater to fresh. It is right at the critical speed of planning out. I will get with some prop shops and see what they can come up with, maybe Carver can assist as well. Thanks again
uaesi
- Vessel Info: 2004 466 Carver
carvergofast
uaesi
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
uaesi
I will definately check that sensor for the drain hole!
The article should help Carvergofast evaluate his condition as he may have something else going on.
- Lyndon670
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
