replacing fresh water pump 1987 3607
RWS
Vessel Info: 1987 3607 aft
Has thanked: 28 times
Postby RWS » April 22nd, 2019, 12:22 am
Replacing fresh water pump on a 1987 3607, what is factory pump size and would a 5 or 6 GPM pump give good water pressure? thanks for your help.
Been thanked: 468 times
Re: replacing fresh water pump 1987 3607
Postby RGrew176 » April 22nd, 2019, 4:46 am
Been there done that with my 3007. It had a bad pump when I bought her and it was the first thing I had to fix. I did do it myself but it was a pain to access on my boat. Hope yours goes easier. I don't remember what rating of pump I bought unfortunately. Good luck with yours.
2022 Stingray 182 SC
Been thanked: 246 times
Postby mjk1040 » April 22nd, 2019, 5:48 am
I'm thinking the original is half of what you are thinking in your post. Closer to 2.5-3gpm @ about 45 psi. If your plumbing isn't sized correctly a bigger gpm/psi pump may not be able to function properly. I went from a Shurflo to a Seaflo and the unit is so quite I have to turn everything in the boat off to hear it run. Thought the Shurflo was bad, turned out inlet filter was plugged up, may be your problem to? Hope your repair goes easy!
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » April 22nd, 2019, 7:10 am
Yup, seems to me most of the original pumps were around 3 gpm. There are some here that have the same model that could verify....
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 284 times
Postby buster53 » April 22nd, 2019, 2:40 pm
I replace my pump on my 3807 and I believe the old one was about 3 gpm. I stayed with that size. A bigger pump will empty your limited size water tank quicker than a small pump.
darrenlife
Vessel Info: 2002 Carver 410 Sport Sedan
Been thanked: 36 times
Postby darrenlife » April 22nd, 2019, 3:06 pm
My ‘new to me’ boat came with a accumulator. I haven’t had a chance to try it yet but may be a solution if you’re finding the pump to pulsing.
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » April 22nd, 2019, 9:29 pm
Don't go with a larger pump without checking weather your current wiring will handle the extra load or you will have to replace the wiring to accomodate it.
Postby RGrew176 » April 23rd, 2019, 2:26 am
darrenlife wrote:Source of the post My ‘new to me’ boat came with a accumulator. I haven’t had a chance to try it yet but may be a solution if you’re finding the pump to pulsing.
It will definitely help. For the heck of it I disconnected my accumulator a couple of seasons ago to see what would happen. It pulsed like crazy. Reconnected the accumulator and pulsing went away.
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » April 23rd, 2019, 8:50 am
I have the same boat. I think my current pump is a 5 GPM and it is just fine. I did put an accumulator in they system a long time ago and it makes a VERY nice addition. I mounted it under the aft berth in the very aft port corner. It made the plumbing very easy. Just "T" it in on the output side of the pump line.
I had put in one of the "smart sensor" pumps and that was a BIG mistake. It was nice a quite (starts slow then ramps up to full speed, instead of just kicking on and off). It was an expensive pump but failed just outside warranty. I replaced that with the less expensive on/off type and it's been fine for ~10 years.
Been thanked: 1180 times
Postby Midnightsun » April 23rd, 2019, 12:28 pm
Seaflo makes some nice pumps that eliminate cycling with no required accumulator due to design. Nice units that do not break the bank. Here is a video showing the cycling issue that are commonly found when no accumulator is used. This is 3gpm which is more than sufficient for our boats.
