Fuel sending units
- 1992330aftcabin
- Vessel Info: 1992 330 Carver aft cabin
- Has thanked: 54 times
- Been thanked: 32 times
Fuel sending units
Thanks Mike
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Fuel sending units
- Has thanked: 602 times
- 1992330aftcabin
- Been thanked: 1112 times
1992330aftcabin wrote:Source of the post.... after filling the fuel tanks gages only read half tank on both tanks....
Do you have separate gauges or one gauge with a switch? If it's one gauge, I'd check the gauge before I started digging into the senders.
- 1992330aftcabin
1992330aftcabin wrote:Source of the post KM1125, I have duel gages no switch. I find it funny both gages won’t go above 1/2 when tanks are full.
That is interesting....can you tell if the gauges are the originals or been changed out.....maybe they don't match the rest of the dash...???
- 1992330aftcabin
Now I do not know what it will do as they sometimes work backwards depending on which one you have but my guess is it will go to full which will confirm a sensor problem or bad connection most likely at the sensor. If it pegs to empty, simply remove the sensor wire and it should peg to full. The ignition does need to be on during your test by the way. If they peg to 1/2 it is the gauges or the supply of 12v to them is low.
Users browsing this forum: No registered users and 40 guests
