97 Mariner 350 - Pleae help decide
- mobinakhtar
- Vessel Info: 2003 Viking Princess 65
1988 Carver 3207 Convertible
1971 Hatteras 38 Convertible
2005 Boston Whaler 15 Montauk - Location: Freeport, TX
- Been thanked: 7 times
Re: 97 Mariner 350 - Pleae help decide
This is going to be my first "yacht" so I am still looking around for a slip - trying to find where to buy gas on the water etc. My friends keep telling me to buy a smaller boat that fits in my own boathouse and is easy to maneuver (9' beam restriction in my boathouse ). That's a great idea but I cannot find the right boat for that either. I want something that looks like a sedan but has no stern drive and a beam narrower than 9 ft.
- Has thanked: 78 times
- Been thanked: 1093 times
I do think those engines are a bit underpowered for that boat. My boat weighs 18,000 lbs too and I have twin 350HP engines. I'm not a speed demon in this boat but I couldn't imagine having much less power.
If top end is REALLY not an issue, if everything else looks good on the boat you could downsize the props. This would give you all the power to get up on plane even in "not-so-ideal" conditions and regardless of load, but may take 2-4 MPH off tops speed and knock a little off cruising speed so the engines aren't running at 4,000 rpm all the time. It's an option for you that might make this boat workable for you given your requirements. You can also save the original props as spares in case anything happens and you need a temporary set (I think you should always have a spare set available)
- mobinakhtar
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
I would think that top end and cruising speeds would be similar to mine. At least it gives you an idea. Obviously your sea trial will answer all your questions concerning top end and cruising speeds.
Good luck. I hope all goes well.
2022 Stingray 182 SC
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
- mobinakhtar
- mjk1040
- Been thanked: 246 times
- Been thanked: 601 times
- RGrew176
tomschauer wrote:Source of the post Shouldn't everyone have at least two boats?
Technically I do have 2. The 30' Carver and a 10' 4" Aventus inflatable. Thinking of adding a PWC to my fleet next year.
- mobinakhtar
