New Owners: 2003 Carver 396 Aft Cabin MY
- mobinakhtar
- Vessel Info: 2003 Viking Princess 65
1988 Carver 3207 Convertible
1971 Hatteras 38 Convertible
2005 Boston Whaler 15 Montauk - Location: Freeport, TX
- Been thanked: 7 times
Here are some details:
Twin 8.1L Crudsaders 502's w/ Captains Choice with about 104 Hrs Each
7.5KW Kohler Genset with 130 Hrs
Floor Plan A (dual sofa space, no dinette) with recessed kitchen and a larger VIP guestroom
Twin Raymarine Hybridtouch screens (GPS and Radar - switchable) Tridata and autopilot. new in 2016
Fusion modular sound system with network and Bose speakers
new exterior upholstery and brand new bridge enclosure
Dighy, Davit, 5hp Mercury 4-stroke (2016)
Here is the work needed:
Bottom job is 3 years old - considering pressure wash to decide if need a new one
Wax and Buff is also 3 years old
Engine hoses and belts were done 3 years ago - check and replace
Water pumps - 3 years old and ran 10 hrs but I'm replacing them
5 new batteries needed (4 are not holding cranking charge)
Aft and Fwd cabin smaller AC units are out - need to troubleshoot as compressors are not engaging. units look rust free and new
starter solenoid for generator is out. I was able to test crank it manually
port gas tank sender is broken (and its completely out of gas)
needs a great deal of cleaning.
so far these are the main items. I checked all seacocks etc. all seem to be ok and working.
- mobinakhtar
Re: New Owners: 2003 Carver 396 Aft Cabin MY
Please feel free to advice me on anything you guys recommend I check. Never owned a motor yacht before. I am familiar with boating and 20-25 ft boats - single engine.
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
Aren't 8.1's = 496 and 8.2's = 502?
I have 8.1's in my Carver 356. Great engines, but I'm having engine problems with my port engine at the moment. Trying to line up a mechanic now.
My Crusaders are 385 HP ea. Boat will fly...35 MPH at wide open.
- mobinakhtar
Repair Update: Poured 5 gallons of fresh gas in each tank. Replace 5 New Marine batteries and Started engines.
Port hard to start and dies after running perfectly for 20 seconds. seems starved for fuel.
Starboard is idling smoothly - some pulley is making a screechy noise.
trying to diagnose port. Have feeling has something to do with fuel, fuel pump, or filter or worst case injectors. This engine has 108 Hours on it.
Removed starter relay for Kohler gen and ordered it. It will crank if the starter is shorted so definitely the solenoid is bad.
- buster53
- mobinakhtar
- buster53
Come back here and let us know what you find. Water in my tank is what is causing my engine issue.
The first time I did this, it was almost all water in my filter. Very little gas.
- mobinakhtar
- buster53
I would drain it once to see how much water is in it. You may want to do it again and then actually replace the filter itself.
- buster53
