Marine Air A/C blows breaker instantly
- golgi
- Vessel Info: Carver 530 Voyager Pilothouse
- Has thanked: 19 times
- Been thanked: 6 times
- Been thanked: 490 times
Re: Marine Air A/C blows breaker instantly
I''d start with disconnecting and protecting the termination at the ac unit, and flipping the breaker. Just to make sure the line between the breaker and the unit hasn't been compromised.
- golgi
waybomb wrote:Source of the post Blowing instantly, meaning, as soon as you flip the breaker before turning on the ac unit?
Yes, exactly. No chance to even turn it on at the A/C control unit. Breaker pops as quick as you can flip it on. Unplugged the phone-like jack from the control panel to make sure it wasn't causing the problem. Same result.
I will disconnect the wires from the A/C unit next and see if that makes a difference at the breaker. Thanks for the suggestion.
Just make sure you unplug your shore power before playing with ac on a boat
- golgi
So bad board possibly?
- Has thanked: 602 times
- Been thanked: 1310 times
Do this with all power off....that means shore and any inverters you may have. FYI I have had wiring get a small cut and rub against a receptacle housing and cause just what you are seeing.
- golgi
Unfortunately, I had to return to the real world so I'll get into it again this weekend. My circuit goes from breaker to control board to A/C unit. I think I'll kill the power and inspect and reinstall all leads and grounds on the board and then go from there. The wires are jacketed, insulated and then inside flexible conduit. I can't imagine I've got a rub through but who knows. Like you said bud, maybe inside a junction box. When I test for dead short would I just run a lead wire from the connection in the master to the engine room? The multimeter isn't gonna cover that distance
I consider myself good at many things, but the dark magic of electricity is not one of them!! Lol
I have a 20ft piece of wire with alligator clips to help with testing from one area to another....good luck man, take your time be safe and you will find it.
- golgi
