'86 Carver Monterey Port Prop
HaasNation
Vessel Info: 1986 Carver Monterey 29
Postby HaasNation » June 5th, 2019, 10:37 am
Hey Guys,
Father and I picked up an '86 Monterey from his friend who just passed. The port prop is bent bad (thanks to me allowing dad to operate it first). :banghead: Could use some help finding a replacement since I'm very green with anything bigger that a 20' Spectrum. It's an 18" x 20 DQ. Looking for brass or aluminum. Engines are Mercruiser 350, 5.0L. 270 HP.
Thanks for the help! :usa:
Been thanked: 646 times
Re: '86 Carver Monterey Port Prop
Postby g36 » June 5th, 2019, 11:23 am
Try looking for a prop shop near you they should be able to take care of it no problem.
Has thanked: 64 times
Been thanked: 481 times
Postby waybomb » June 5th, 2019, 1:53 pm
Ebay.
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » June 6th, 2019, 1:14 pm
I'd definitely try a good prop shop to see if they can bring it back. It's amazing what some of them can do. Another thing you might consider is looking for a pair of matching props that are CLOSE to those specs then use the old ones as spares (if the one can be reconditioned but not brought back "all the way").
