Strainers for engines on 3807
- VicB
- Vessel Info: 1988 Carver 3807
- Has thanked: 41 times
- Been thanked: 11 times
I have an 88’3807. It did not come with raw water strainers for the raw water cooled engines. Has 1-1/4” lines from the seacocks to the raw water pumps. I ordered Perko strainers (1-1/4”) due to a stopped up oil cooler. I am assuming adding strainers would only be a plus. Any reason that no strainers would be a better design. I got 1-1/4”. Due to mounting constraints, looks like I’ll need elbows for fittings on both sides. Would that small of constriction with elbows vrs straight fittings even be an issue? Any thoughts on this issue would be great.
Thanks in advance
Vic
- Been thanked: 1111 times
Re: Strainers for engines on 3807
The only real downside is more things to maintain. Need to keep the strainer clean, but if you'd be getting junk in there then better there than in the engine coolers!!. Also need to make sure that the seals are good and you can't suck in air when the engine is really pulling in a lot of water.
- mjk1040
- Been thanked: 248 times
- VicB
- VicB
- VicB
- Has thanked: 602 times
- Been thanked: 1310 times
This rydlyme is basically approx 9% HCL to remove lime scale....I think a strainer in the system is there to keep all the big stuff like sea grass and debris out, two different purposes......really depends on where you boat.
VicB wrote:Source of the post......Viper when you figure out where to mount yours, I’d love to see some pics. Not a lot of room there as you know.
I'm thinking on the outboard side of the centre stringers behind the engines.
Users browsing this forum: sbb2112 and 42 guests
