Kohler Genny Impellor Fried???
Marty
Vessel Info: 2000 326 AFT Cabin
Has thanked: 16 times
Been thanked: 9 times
Postby Marty » June 9th, 2019, 7:23 pm
Had the marina summarize everything engines, water, genny etc and on the hook went to fire up the genny and got a "LOC" error code. Turns out the impeller had 2 fins left so needs replacing, heaven forbid they let me know??
Mechanics at the marina said I should backslash as most of the fins are MIA?
Anyone think this is necessary??
Been thanked: 601 times
Re: Kohler Genny Impellor Fried???
Postby tomschauer » June 9th, 2019, 7:28 pm
Yes, you need to back flush and make sure the missing fins made it out of the boat.
Been thanked: 468 times
Postby RGrew176 » June 10th, 2019, 1:33 am
Definitely yes.
2022 Stingray 182 SC
Marty
Postby Marty » June 11th, 2019, 6:53 am
Reading I can backflush through the twin cooling loop as I am assuming back through the water/exhaust outlet will be a bad decision....not sure where else this would work.
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » June 11th, 2019, 6:56 am
The blades are probably trapped in the raw water circuit somewhere. Check right at the ports in the pump and the inlet to the heat exchanger. Pull the hose off the exchanger output and back-flush through there. Hopefully there're not any further into the system. You should try to reconstruct the impeller with all the pieces you find to ensure you got all of them.
Marty
Postby Marty » June 11th, 2019, 7:14 am
Yes thats where I was referring to thanks....last question...can i flush with the genny off?
Thank you
Been thanked: 246 times
Postby mjk1040 » June 11th, 2019, 5:09 pm
yes u can
