A/C stops A/Cing....
- 650Guy
- Captain
- Been thanked: 37 times
Here is what I’m seeing:
* ac will fire up and run swimmingly for an hour, may even 3 or 4 hours... but then it stops. The fan still blows, and according to the panel it’s calling for cold air, but the water pump turns off and no cold air??
My first thought is the water pump is bad, and once the pump stops the AC shuts off, but I get no HPF error or anything.
On a side note, it has always struggled to switch between heat and cold. Not sure if that plays into it or not. I’m grasping here but thought maybe the reversing valve is bad?
To me the key factors are:
* it’s calling for AC
* no water flow
* works fine for a while then just stops doing its job
Any idea of where to start? Are these units repairable or is it usually a remove and replace type situation?
Thanks all!!
- Been thanked: 1180 times
Re: A/C stops A/Cing....
- 650Guy
- Captain
- 650Guy
- Captain
- 650Guy
- Captain
- BenTen
- Vessel Info: 1984 Carver 3697 Mariner - "We'll Sea"
- Has thanked: 20 times
- Been thanked: 32 times
Ben in SC
- Been thanked: 601 times
If you set it to 72 degrees f, how cool does it get before it shuts down?
Look up the manual and check offsets and auto changer set points. Also many units have a coil temp sensor that will shut off the compressor to keep the coil from freezing. If you have one and it is tripping, most likely a very dirty coil or something else restricting air flow.
- 650Guy
- Captain
- AC
- Fan
- Heat
So times that it will fail, the fan continues to run, the temp will increase, and the light for AC will illuminate, but the sea water pump will not turn on, and AC unit never turns on but fan will and the AC Light will illuminate. and NO error code.
USUALLY when I first arrive at the boat, it all fires up normally and works for a while.. but the longer I'm there and its running, I get issues.
- vineyardgray
- Captain
- Has thanked: 128 times
- Been thanked: 33 times
- Contact:
1988 Carver
3867 Santego
PCYC
