New Boat Owner - Need help with kohler Generator.
mobinakhtar
Vessel Info: 2003 Viking Princess 65
1988 Carver 3207 Convertible
1971 Hatteras 38 Convertible
2005 Boston Whaler 15 Montauk
Been thanked: 7 times
Postby mobinakhtar » June 13th, 2019, 11:23 am
Hello folks, I am very new to yachts and generators. I recently purchased 2003 Carver 396 aft which is equipped with a 10KW Kohler 4-cyl generator. I cannot start the generator using the start button or remote button as it makes a constant clicking sound. One mechanic told me it is the starter solenoid (he jumped the post manually and starter kicked in) so I ordered a new solenoid with a matching part number from Kohler. After replacing the solenoid, it's doing the same exact thing. Someone here (on another post) recommended checking the oil level, which is new and full. I am a bit perplexed. Please help. I have replaced all five batteries just two weeks ago so it's definitely not the battery. I am just wondering if I am replacing a wrong model solenoid (someone put in the wrong model solenoid before my possession of boat) The PO insists it worked when they used it last 7 months ago. They were living in the boat and using shore-power for last few months. Is there a setting, breaker, button or anything I am not doing right. I am at a loss here. Anyone with a carver and a Kohler can you please chime in?
vineyardgray
Has thanked: 128 times
Been thanked: 33 times
Re: New Boat Owner - Need help with kohler Generator.
Postby vineyardgray » June 13th, 2019, 1:00 pm
Where does the Kohler get its 12v power from? Is it a battery independent of the others? A low battery will cause the starter solenoid to click.
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
Has thanked: 64 times
Been thanked: 481 times
Postby waybomb » June 13th, 2019, 1:59 pm
Is the genny battery charged by the on-board charger?
mobinakhtar
Postby mobinakhtar » June 13th, 2019, 2:57 pm
Yes, it has a dedicated battery (New) which is also charged by onboard AC/DC shore charger. As I noted before, I can short the two main post on solenoid and starter cranks. I'll try to make a video and post here.
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » June 13th, 2019, 3:07 pm
You may have a separate starter relay from the solenoid and that's what you hear clicking. I would try to isolate where you hear the clicking sound to verify that. Pics help too so when you're describing something we know exactly which part you're talking about instead of just making assumptions.
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » June 13th, 2019, 3:27 pm
Try to start the generator at the generator........open the breaker on the gen itself and start it from there....see what happens.....there is a Kohler repair guy on here, maybe he will chime in......
Is all this clicking sound coming from behind the panel in the boat or right at the generator ?
Been thanked: 601 times
Postby tomschauer » June 13th, 2019, 8:38 pm
Put voltmeter leads on the solenoid control wires (the small ones) hit the start switch and make sure you have a constant 12 VDC. If you do and it doesn't crank, bad solenoid. If you don't either a bad start switch or something in the safety circuit. You should be able to find a wiring diagram on line, or post your model and serial here, someone may have it.
mobinakhtar
Postby mobinakhtar » June 13th, 2019, 10:01 pm
Clicking majorly appears to be coming from the top black box (one with stickers. In next post, I'll try to put a small video
Been thanked: 246 times
Postby mjk1040 » June 14th, 2019, 6:31 am
I'm thinking bad relay before starter solenoid!
Postby bud37 » June 14th, 2019, 8:26 am
One other thing that comes to mind would be the ground strap from the engine to the tray/pan, then to the battery negative......give that a quick check, clean.
Return to “Electrical”
