Kohler Gas Generator
- Jimmy
- Vessel Info: 2001 Mariner 350
- Has thanked: 2 times
By the way the generator has ran all year with no issues. Thank you in advance with any assistance.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Kohler Gas Generator
One other question...how much fuel is in your tank? I had a boat that needed at least 1/3 of a tank to make the genset run. Anything less than 1/3, the fuel pick up line was now above the fuel level in the tank.
- Jimmy
- buster53
- Been thanked: 490 times
Don;t bother trying to clean; just replace it. It's a lightly loaded spring check. I can't imagine any marine supply store without one.
- Jimmy
- Has thanked: 602 times
- Been thanked: 1310 times
I am guessing you have the 7.3 here....if you check out the parts blow up in the manual you may see whether you have this part and how the fuel feed is configured.
- buster53
Jimmy wrote:Source of the post Waybomb, thanks for the response. I checked the hose from the tank to the valve and there is nothing. I didn’t see a fuel filter but I assume it is between the pump and valve.
If I'm not mistaken, when my mechanic changed mine, it was inside the tank. I do have a fuel filter and it is mounted between the tank and genset. Mine is easy to get to, but I know some boats, it can be very difficult to find and/or service
- Jimmy
Users browsing this forum: Google [Bot] and 43 guests
