Hot Water Tank vs tankless heater
- 650Guy
- Captain
- Been thanked: 40 times
I think my hot water tank has come to the end of its service life. Considering replacing my 11 gal tank with one of those inline tankless heaters. Has anyone done it? the tankless ones seem to be cheaper and would THINK they are more efficient?
Just wondering if anyone has done it and had any thoughts/advise?
Re: Hot Water Tank vs tankless heater
- 650Guy
- Captain
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
- Has thanked: 602 times
- Been thanked: 1310 times
The on demand will draw more unless you get a single point of use unit, which may not give you the hot water needed for a shower, but would work for hand washing, dish washing etc. Also, you would miss the "free heat" you get from the engine heating coil in the water heater ( unless someone changed out the original).
Soooo, keep in mind, your water heater is most likely on a the house 30 amp breaker, along with your batter charger, microwave, stove, receptacles etc. If you install a 120v instantaneous 25 amp heater, you will need to turn off everything else to use it. Or be in the dark with cold water!
- Been thanked: 1111 times
tomschauer wrote:Source of the post Your 120v 11 gallon water heater should draw 12.5 amps at 120 volts. Lower voltage at the dock, higher amperage.
Agree with all that except the "Lower voltage at the dock, higher amperage". If the shore power voltage drops, then the amperage drops as well on the water heater, as it's just a resistive load. That also means less heating power, so if you have low voltage at the dock it will take longer to heat the tank.
Even if you could install a 120v 25 A "instant" heater, it would take 15 minutes to heat 6 gallons of water from 60F to 120F, so it might be a long shower or a pretty cool shower (if you're using both hot and cold water).
Many here use one like this on the swim platform from a wash down pump. Works well but does require propane. https://www.ebay.com/itm/5GPM-LPG-Propa ... 0005.m1851- andreww
- Vessel Info: 2016 Delphia Escape 1080 S
