Kohler Gas Generator
Re: Kohler Gas Generator
The fuel line will hook up to it right at the top of the tank. Because of it's profile, it's hard to tell that it's actually there but unless it's been removed in the past, it'll be there.
There's likely a fuel filter in the generator too. Did you check it? Have you properly diagnosed and tested the fuel pump before you spend the money on a new one? How did you determine that it's not working or that the unit isn't getting fuel?
It would help if you posted the model number of the genny.
- Keith S
- Vessel Info: 2005 38 Super Sport
- Been thanked: 21 times
Whenever I suspect a fuel system problem, the first thing i do is run the generator off a separate 1 gal tank to isolate the generator from the boat system.
csdaman2
- Vessel Info: 1996 Carver 355 Aft Cabin. Twin 454 Crusader's. Vessel Documented with the name "Justified"
- Has thanked: 3 times
- Been thanked: 2 times
csdaman2
Users browsing this forum: Google [Bot] and 42 guests
