Low Battery Warning
- Sadey
- Vessel Info: Former owner of a 2003 Carver 356 with 8.1 Mercs
Agradecida
Current owner 1989 60’ Hatteras MY with 8v92 Detroit’s
Benedetto - Location: Racine Wisconsin/Ft. Lauderdale
- Has thanked: 4 times
- Been thanked: 29 times
Low Battery Warning
By the way Fayette Michigan is a fantastic harbor and cool place to see. Brand new docks with power. Make sure to hit Sherry's Port bar. Its about a mile walk south past the cemetary for cheep beer. Not a culinary delight but nice walk and very friendly people.
Dave & Trina
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Re: Low Battery Warning
..Aaron
SeaDragon
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
However, you will find that your battery switch, under the step, must be set to ALL or BOTH when underway for the alternators to charge ALL of your batteries, including your house battery. The alternators will only charge what the selector switch is set to when underway.
Hope this helps.
Tireless
- Sadey
Agradecida
Dave & Trina
- Tireless
- Tireless
The selector switch was designed to enable you to select Bank # 1, Bank #2, BOTH or turn them OFF. Do you have another switch on your boat that would enable the Bank selections as described. There are also breakers beside the dial for the charging system.
In your boat, how are you selecting battery banks, that is where the problem may be. In my 356, I had Bank #1 for the starters and Bank # 2 as the house. Is it possible that someone changed the switch under the step to an on/off prior to you buying the boat. If so, this maybe the issue as you can't draw from Bank 1 and 2 individually. You would want to do this so you can keep a battery in reserve in case of emergency starting. A a stated before, the batteries must be set on both for the alternators to charge while underway.
My 2006 is set up the same with on/off switches for all the batteries with combiners that do the charge allocations.
- Sadey
Agradecida
Thanks again for the help/suggestions.
Dave & Trina
- Tireless
