Crusader 350 not starting after winter
- Torsson
- Vessel Info: Carver 28 Voyager 1988 Twin 350 Crusaders
What i can tell is that the engine gets to much fuel.
Sorry for my bad english.
- Has thanked: 78 times
- Been thanked: 1093 times
Re: Crusader 350 not starting after winter
If it is carbs then yes you have chokes and sometimes they do get stuck or the thermostat element that controls them is either stuck, broken or bad. It is easy to check by having the engines nice and warm, shutting them down and taking the flame arrestors off. The chokes should be wide open at that point. If not you have to figure out why they aren't.
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
- Torsson
https://cloud.gaslampa.se/s/7eC5d3uecWbe9St
Sorry for late reply did not have notifications and had much at work so it was lovely to start vacation with one bad engine
- Been thanked: 601 times
It sounds like you may have a bad accelerator pump or a clogged port from the pump, but start with the simple cheap stuff like filters.
- Torsson
- Torsson
tomschauer wrote:Source of the post I believe the crusaders also have a :cleanable: screen filter that is round and flatish.
If you mean that one after fuel line before carb I looked at it when I took the carb to pieces and it was clean
I think you're referring to the Oberg filter. That was only on later model Crusaders from that I understand.
If you have Rochester carbs then you might have a small sintered bronze filter where the fuel inlet goes into the carb. You remove the fuel line then remove the "big nut" to get to it.
It does look like you have a problem with the accelerator pump, as it should spray in both venturies equally. That might cause your hesitation, but would not cause your 3200 RPM problem. The accel pump only functions when there's a CHANGE in throttle but once at any given setting it doesn't affect mixture (that's why you don't be able to detect a lean condition from just an accelerator pump issue). Check to make sure you're getting mechanical advance on your timing and check all the fuel filters so nothing is restricting the full flow of fuel to the engine. Might also check/replace the anti-siphon valve too.
- Torsson
.. Somehow after changing sparkplugs. cleaning the flame resisstor and cleaning the carb that engine runs very nice now. Now i need to start with next project, finding out why the other engine overheats. Impeller looks nice but the belt that drives that pump seems to be little to loose and it is very hard to get access to tension it and my belt dealer seems to have hard time to find correct new belt. The thermostat opens nice when boiled. next need to be the "internal" water pump i assume.Return to “Gas Engines/Transmissions”
