1994 390CPMY w/Kohler 6.5
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Re: 1994 390CPMY w/Kohler 6.5
Postby tonyiiiafl » July 14th, 2019, 10:02 am
tonyiiiafl
Postby tonyiiiafl » July 14th, 2019, 10:06 am
tonyiiiafl
Postby tonyiiiafl » July 14th, 2019, 10:10 am
Got the capacitor out. It was nestled in under the control box. A little tapping on the screw and contortion and it came out. I checked the voltage with my meter and no AC or DC. Then I saw the hole in the side. I am thinking this is the culprit. I will order an OEM one today and then see if it solved the issue, which I think it will, with the hole and all.
Postby bud37 » July 14th, 2019, 11:05 am
That is quite the catch... :down: ......looks like something punctured it....hopefully that is it...
tonyiiiafl
Postby tonyiiiafl » July 14th, 2019, 11:59 am
I SO hope so/ I was suspicious when there was no voltage stored in the capacitor. THAT made me a bit confident.
tonyiiiafl
Postby tonyiiiafl » July 15th, 2019, 8:34 pm
Found a capacitor. I am lucky I was able to read the GE number to get the data for a new one, as my Genset Model and serial number sticker is missing. I am so happy the previous owner kept all the manuals and I was able to get a model number. KUDOS to Coburn Power in Illinois for their great help and also South Shore Generator in Wareham. I have one coming from each 2nd day air. Fingers crossed!
tonyiiiafl
Postby tonyiiiafl » July 17th, 2019, 4:35 pm
I think I have solved the issue. I replaced the capacitor. I also bought a spare, why who knows? However, upon installation, I started the genset and right away power kicked the contractors in. I had 110V on the gauges and when I put a multi meter on the circuit it was 109.7 to 111.5 with no load, or slight load, the battery charger. When I placed a load, it went right up to 120. A/C started instantly and you could see the load come up on the load meter and hear the genset hunker down a bit and then relax. I would say I have solved the problem. However, I was unable to get the screw back into the clamp, so i used a tie wrap for now. This weekend I will drill the hole out a bit and place a brass 6/32” screw and nut in there to hold it steady. Let’s see how this works this weekend.
Been thanked: 248 times
Postby mjk1040 » July 17th, 2019, 7:27 pm
How did it get punctured?
tonyiiiafl
Postby tonyiiiafl » July 17th, 2019, 7:38 pm
I truly do not know. I had a heat exchanger put in over the winter and that is the only thing I can think of. No other work was done by me on the genset
Keith S
Vessel Info: 2005 38 Super Sport
Been thanked: 21 times
Postby Keith S » July 19th, 2019, 7:26 am
I'm a little late to the discussion, but 2 things to know. The no-load speed needs to be at 62hz which is about 3700rpm. With a load it will drop down to 60hz or 3600, Kohler recommends that with the automatic transfer switch used on the Carver, you should use a 25mfd capacitor instead of the 20mfd to allow quicker voltage build up. That model was the only one Kohler made with capacitor excitation and it had some issues.
Return to “Electrical”
