I hear ya on the gong show....
tomschauer wrote:Source of the post Marty, if you were able to achieve 4k previously with the same props, that's not the issue.
Did they check the fuel pressure while running (under load)?
As far as the alarms, on a 2000, it should have been high engine temp, low oil pressure or high trans temp.
Marty wrote:Source of the post Yes especially on our leg between kincardine and tobermory I encountered 6-8 footers off my port?starboarded and we're chasing waves for 50 miles. Engines purred liked kittens back and forth and only on the last trip back to port last season did RPM's become an issue.....
Users browsing this forum: No registered users and 47 guests
