2003, 360 Sport Sedan
- tjh408
- Vessel Info: 2003 Carver 360 Sport Sedan
- Has thanked: 18 times
- Been thanked: 9 times
At this point we were out of time and will come back for the sea trial and short haul Wed.
Any thoughts on the low voltage and idle for a computer controlled motor would be appreciated. Also thoughts and comments on this model would be very much appreciated.
Great forum
- Has thanked: 602 times
- Been thanked: 1310 times
Re: 2003, 360 Sport Sedan
Oh, the add....if one engine was running and then stalled as a result of the second starting, that could be a result of low voltage for various reasons.....lets see how it goes on your trial.
- tjh408
If you post engine serial numbers, I can check to see if there are any active campaigns on those. Other than that, they're typically good engines. I suspect this is a salt water application? If so, try to find out how old the exhaust elbows are, and the manifolds if they are raw water cooled. Any hardware with salt water running through it; heat exchanger, oil coolers, etc. are worth digging deeper as they only last so many years in that environment. If they've never been replaced, consider that in your budget for the future.
Good luck and keep us posted.
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
- tjh408
Thoughts?
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- tjh408
- tjh408
