clear water pump line
- drmax
- Vessel Info: 1987 32
- Has thanked: 2 times
Heard an odd noise from friends boat yesterday. In front of the left engine, on the floor lays a pump. There is a clear line, may 3/4" that has came off from somewhere and basically this pump was pumping air. Went to the circuit panel and flipped a breaker title "water pump". Tripping this breaker stopped the motor. The line on the other side of the pump disappears somewhere behind what looks like may be some sort of liquid storage tank that sits outboard and just in front of the eng. At this point I'm assuming that tank is a fresh water tank (which she never uses) and the loose line is suppose to be connected inline to the boats water supply? I suppose I can test this theory by putting some water in that tank and seeing if it goes through that pump. There is regular water in the sinks from the shore water. One would think....that with this line off there would be water flowing out somewhere, unless there are seperate water lines on the boat, or some sort of check valve. Hell, maybe I'm way off here. What is this water pump suppose to do and how is it activated? Does it run all of the time?
- Bandit
- Vessel Info: ‘99 Carver 404
- Been thanked: 4 times
Re: clear water pump line
Not familiar with dock water supply systems and how they are plumbed but If the pump stays running then you have a leak or in your case seems the line came off.
- Been thanked: 1111 times
If it's a 120V breaker, then it's the water pump for the heat and air conditioning. If it's a 12V breaker, then it's the water pump for the potable water if you're using the onboard water tank. If you're using a dockside connection for water, then you're on city water pressure and don't need the pump to run at all.
- Has thanked: 602 times
- Been thanked: 1310 times
drmax wrote:Source of the post 32' aft cabin.....
Until you can pin down what is going on there with the pump and line etc.....may I suggest not to leave the city water on when the boat is unattended.....if that is the freshwater pump and the inside/check valve is damaged you can sink the boat....
If it's the fresh water pump and the intake hose from the tank to the pump is off, you shouldn't get water coming out of that hose while the dockside water is on if the check valve in the pump is functioning properly. This prevents the tank from filling up and overflowing while connected to dockside water. There is only one fresh water plumbing circuit on board whether using the on-board water from the tank or dockside.
This could be a matter of the line taken off for winterizing and never put back on. Either way, it needs to be determined which line/which system it is and hooked back up for safety reasons.
- drmax
(I'll attempt to load a couple pics here if it isn't too difficult)
- drmax
Users browsing this forum: No registered users and 50 guests
