Need help troubleshooting Alarm on 8.1L Horizon engines
- mhanch
- Vessel Info: 2000 Carver Voyager 374
Twin Gas Mercruiser 8.1L Horizon engines (2007 Repower) - Location: Renton, WA
- Has thanked: 5 times
- Been thanked: 6 times
- Contact:
I've got a 2000 Carver Voyager 374, and it has twin Gas 8.1 Liter Mercruiser Horizon engines (they are a repower from 2007). The boat is new to me, and what's happening is that the engines run great, but after about an hour of running around 1000 rpm (navigating a long no wake zone) i get a solid alarm buzzer from the Port engine.
- the oil pressure is normal
- the temperature is normal
I thought it might be the impeller, so i had that swapped out. that wasn't it. Once the alarm starts, i can't run the engine untiol the next day or it keeps going off. Next, I had a Mercruiser mechanic come out and check the engine for any stored codes. there was nothing, and he couldn't reproduce the issue.
I have a vessel view on order to attempt to gather more data, but I was wondering if anyone here had any ideas of what to look for?
Thanks for any help.
- Been thanked: 601 times
Re: Need help troubleshooting Alarm on 8.1L Horizon engines
- mhanch
- Contact:
Edit: Looking over other posts, advice seems to be to just change out the Oil if in doubt. Pump it all out, refill. then drive a bit and repeat. after that it should be good. and Dexron III for the velvet drives. I'll give that a shot on both engines.
- Has thanked: 469 times
- Been thanked: 1765 times
The alarm could be a number of things. When the alarm sounds, have you tried increasing rpm and if so, what happens? Does it allow the engine to increase rpm or does it go into Guardian mode and limit your rpm?
If they can't duplicate the alarm, it's difficult to tell what the cause is. Of course it won't happen when the tech's on board. It would be nice if they had hooked up Merc's recorder and sent you on your way for the weekend with it. When the alarm or problem occurs, you push a button and it starts recording engine data for a while. It then gets hooked up to a computer so the tech can see the data and determine the fault.
Are you sure it's an engine alarm and not a fume detector alarm?
- mhanch
- Contact:
Yes, getting the Vessel View will be helpful so I can capture data while we are out. It's a pain not to know what's going on.
- pepmyster
8.1 Volvo Penta
- Has thanked: 487 times
- Been thanked: 206 times
https://www.youtube.com/watch?v=pc4IiTsmsl4
- mhanch
- Contact:
tomschauer wrote:Source of the post Before you go out and buy a vessel view set up make certain your engines are compatible. The 2000's probably are not compatible.
Yes, my engines are 2007 repowers. so they should be compatible. Mercury noted anything above 2004 with Smartlink, which is on my documentation.
- mhanch
- Contact:
I'll take a longer drive when I get the Vessel View, but this was a good sign. Thanks for the advice!
Now I just need to fix/replace a leaking water heater....
